kz1300 banner
Tyre pressure
  • PaulD
  • PaulD's Avatar Topic Author
  • Premium Member
  • Premium Member
Tyre pressure
3 years 1 month ago
#31155
I’m sure I’ve asked this before but a search doesn’t reveal anything?
what tyre pressures are you guys using front and rear (standard size tyres)
  • dcarver220b
  • dcarver220b's Avatar
Re: Tyre pressure
3 years 1 month ago
#31158
I'll have to look! Too many bikes, so each tire has a silver marker denoting appropriate pressure for that tire.
The following user(s) said Thank You: PaulD
  • Ted
  • Ted's Avatar
  • Premium Member
  • Premium Member
Re: Tyre pressure
3 years 1 month ago
#31159
From 40 to 45 lbs, but no less than 40.
1981 KZ1300, '98 Suzuki GSF1200S, Honda CL360, Honda CB350G,'11 Honda CBR250, '75 Honda CL360, '00 Honda XR100R
Speak softly and mount a fast bike.
  • Kawboy
  • Kawboy's Avatar
Re: Tyre pressure
3 years 1 month ago
#31161
I've learned over the years to question everything that I find on the internet because since Youtube, and Facebook etc. anyone can post anything and it's the "Gospel according to Moses"
I'm sure Ted has reasons for his tire pressure settings and I respect that. For me, I always want to go back to an engineered spec and in the case of these KZ1300's the spec for tire pressure would be found in the Owner's Manual so.......
On page 88 of the Owner's Manual
That's what Kawasaki called for.
The following user(s) said Thank You: Bucko, zed_thirteen, PaulD
  • Kawboy
  • Kawboy's Avatar
Re: Tyre pressure
3 years 1 month ago - 3 years 1 month ago
#31162
There's also a "Tire and Load Data" label attached to the bottom of the seat pan. A reproduction label is available from FleeBay.com  Reproduction Tire and Load Data label  but looking at the pressures on this label I "suspect" that this is a reproduction of the ZN1300 Voyager label since the pressures noted on the label are slightly higher than the pressures quoted in the Owner's Manual for the 1979 KZ1300.
Note on the label, the rear tire spec'd is a MU90-16 so 16" diameter rear tire is for the Voyager.
Last edit: 3 years 1 month ago by Kawboy.
  • BigSix
  • BigSix's Avatar
Re: Tyre pressure
3 years 1 month ago
#31164
Between 33 and 36 psi (we measure in bar).
Holger
Z1300 A1/ KZT30AG built 1979
frame KZT30A 004285
engine KZT30A 000288
Time to create page: 0.176 seconds
