kz1300 banner
what 4 piston brake calipers ????
  • bobber-edd
  • bobber-edd's Avatar Topic Author
  • Premium Member
  • Premium Member
Re: what 4 pots
11 years 10 months ago
#4172
i think i will get a couple of pm calipers and make them fit with a home made bracket seems the best a cheapest way forward
zed 13 1979 A1 model
  • RickG
  • RickG's Avatar
Re: what 4 pots
11 years 10 months ago - 11 years 9 months ago
#4173
No eBay APP ID and/or Cert ID defined in Kunena configurationI have a big mess in the mancave at the moment so give me a few days and I might have a solution by using some readily available BMW Brembo calipers
They are K/R1100 and would only need an adapter that would be easy to make
Z1300 A1 x 2
Last edit: 11 years 9 months ago by KZQ.
The following user(s) said Thank You: bobber-edd
  • bobber-edd
  • Premium Member
  • Premium Member
Re: what 4 pots
#4181
any luck yet rick ?? really is there no other kawasaki brakes that fit straight on ???
  • RickG
  • RickG's Avatar
Re: what 4 pots
#4189
Probably some time today I might be able to actually get to my Z13 as its been buried at the back of the cave for some time.
Z1300 A1 x 2
  • Phil
  • Phil's Avatar
Re: what 4 pots
#4202
tackelhappy wrote: Make a bracket and you could do the conversion for $500 or so .
Go the the german site and buy theirs for about 1200 euro.
www.z1300.de/
Pre-tech in England make a direct 6 piston bolt on for about the same money.
There's a picture of the set up on Phil's bike in the gallery.
They also do bespoke 4 piston calipers which are more than adequate. To answer the original question I'm not aware of any other calipers that are a direct fit.
  • kennyb
  • kennyb's Avatar
Re: what 4 piston brake calipers ????
#4203
1199 Euro is about $1600 US! That German site is very pricey.I want to do the same project but I'm on a budget as well.Here is a link from the VTX forum in which someone did the same conversion. www.vtxcafe.com/showthread.php/44351-6-P...liper-Upgrade-How-To
This will give you a idea to make your brackets.
Time to create page: 0.166 seconds
