kz1300 banner
Welcome to the Kunena forum!
Bike won't start
  • Ager
  • Ager's Avatar Topic Author
  • Senior Member
  • Senior Member
Re: Bike won't start
11 years 1 month ago
#6842
so the pin is on a spring is that correct i have machined a pin but this would lpck the advancerin place
  • Kawboy
  • Kawboy's Avatar
#6843
Ager wrote: so the pin is on a spring is that correct i have machined a pin but this would lpck the advancerin place
A spring pin is a silly name for a spiral wound pin which is made of a piece of tool steel sheet metal and wound up like a roll of toilet paper. When the pin is inserted in a bore, the pin holds itself in place by spring tension in the bore.
You should be able to pick up a spiral wound pin from a good hardware store or automotive supplier etc. just size it slightly larger than the bore and press it in.
Time to create page: 0.157 seconds
