Welcome to the Kunena forum!
New Member w/ barn find starting restore 80 kz1300
- hoppy8741
- New Member
11 years 4 weeks ago
I just picked up an 80 kz1300 and 86 vulcan 750. After cleaning off 10 years of dirt and debris from the projects I'm itching to get started. I will as soon as I get manuals for each ordered. On a good note, both bikes show clear oil in the engine and a pretty green fluid in the radiator. I've posted pics on FB but would welcome any tips from those that have already done this type of project.
- Kawboy
Re: New Member w/ barn find starting restore 80 kz1300
11 years 3 weeks ago
Welcome aboard Mister! Gotta love those barn finds and blessed are those with the will to bring them back to life.
You'll want to visit the FAQ button at the top of the page. There's a great article on the issues that members have found and some of the remedies that have been exercised to fix them. Good luck with your projects and don't be afraid to post your questions. Great bunch of guys and gals here to help you with advice.
Kawboy
Kawboy
- Lucien-Harpress
At this point, it's about hitting the basics- clean carbs, valve, and compression check. Once you dive into it a bit more, you'll know where to focus.
Cam chain tensioners are a frequently-cited weak point. I say keep an eye on them. Some upgrade to manual tensioners, others have run tens of thousands of miles on the stock tensioners with no problems. Use your judgement, and check the FAQ for alternative fixes.
What's the plan with the bikes?
- hoppy8741
- New Member
Rebuild both sell 1. depends on which one I like better.
- hoppy8741
- New Member
Okay, carbs are pulled...a little dusty but the diaphragms and floats seem okay. The gas tank was pulled before storage so no varnish in the bowls. Pulled plugs, visual inside looks fairly clean. No power after battery swap will work on harness tomorrow I guess. Lol, forgot its a touring model so I've pulled the fairings, and radiator for better access.
- kza13
Check the key switch under the side cover, that will give no power, also there are manual downloads here for it so you can download them and get started on the 13
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
Time to create page: 0.177 seconds
