kz1300 banner
Welcome to the Kunena forum!
Wanted but dont laugh
  • homer01
  • homer01's Avatar Topic Author
  • Premium Member
  • Premium Member
Re: Wanted but dont laugh
10 years 10 months ago - 10 years 10 months ago
#7918
This would of happen last wkn so the missus would of picked up what he has dumped during the week :lol: I still have 2 so I can get some made (never thought of that) I am glad I am not that dog having to shit those discs out unless the mongrel has buried them some where. Had a look today and havnt noticed anything else missing so all good
Last edit: 10 years 10 months ago by homer01.
  • RickG
  • RickG's Avatar
10 years 9 months ago
#7920
Have you thought of using a metal detector in his favourite places?
Z1300 A1 x 2
  • homer01
  • Premium Member
  • Premium Member
#7922
Sure have, bought a cheap one of ebay a couple of yrs back but I think they went missing last wknd so stuff that has been dropped during the week has been binned and gone, have looked at his burial spots but no good.
Still on the lookout as I tried today but they reckon they couldn't build them as they need to be pretty spot on :(
  • homer01
  • Premium Member
  • Premium Member
#7923
  • Kawboy
  • Kawboy's Avatar
#7925
homer01 wrote: Still on the lookout as I tried today but they reckon they couldn't build them as they need to be pretty spot on :(
You can do this Buddy. Get the brass shim plate stock, drill one of the two holes and then screw one of your butterfly plates to the shim plate, locate the second hole using the drill bit and drill the second hole. install the second screw. then use a scribe and mark the circumference of the butterfly plate. Dismantle the shim stock from the butterfly plate and cut off the excess material. Take a felt marker and run it around the circumference of the butterfly plate. bolt the two pieces back together and hand file the outside diameter of the shim stock and watch the marker on the outside of the butterfly plate. If it starts to come off, you know your at the point of stopping the filing in that spot.
I made duracon washers for the carburetor piston valves this way and Zed_thirteen can attest to the fact that they were spot on.
  • zed_thirteen
  • zed_thirteen's Avatar
#7926
Hi Kawboy, the duracon washer was spot on thank you.
Sorry to put a bit of a downer on this idea but I think the top and bottom edges of the throttle plates are angled - if you look at the plate from the side you can see its rhomboidal
I think Homer's best bet is to be patient and just keep buying the individual carb bodies that come up on eBay now and again (as long as they have throttle plate) until he has enough. I often see carbs that are listed but missing loads of bits like pistons, needles, floats etc.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
Time to create page: 0.209 seconds
