Welcome to the Kunena forum!
Fan Switch temperature Sensor
- Mark
- Elite Member
10 years 6 months ago
Hello All,
has anyone made a repair to a Fan Switch Sensor when the connector spade has broken, if so what sort of repair did you do. Has anyone used a self tapping screw to replace the spade and connected a terminal to that.
Attachment not found
17 years a Z13 owner at present 3 x A1's and an A4
- kza13
Re: Fan Switch temperature Sensor
10 years 6 months ago - 10 years 6 months ago
I used a screwdriver and dug out the sealant around the broken spade connection and got down to a decent area where I just gently soldered on a new spade then just filled around it with a bit of araldite (epoxy resin), good as new, many miles and still working, cheers Pete
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
Last edit: 10 years 6 months ago by kza13.
The following user(s) said Thank You: Mark
- Mark
- Elite Member
Yea Pete sounds good to me, don't intend to scrap them as replacements aren't cheap, have 2 to repair from boxes of bits that I have, so any ideas are good ideas
- aus_z1300
- Elite Member
Sometimes it is a lot cheaper to match it with a commonly used car part.
Not that I have done it with this switch but I have done with heaps of other bike temp oil switches even fan motors on bmw's etc.
Tridon carry quite a few and are available at just about every spare parts shop here in aus.
www.tridon.com.au/products/Tridon/35/483.../thermo-fan-switches
Last edit: 10 years 6 months ago by aus_z1300.
- kza13
There was a thread or post somewhere here where someone drilled and tapped out the hole and used a different switch, you just have to make sure it switches on at the right temperature, forget what temp they said it works at sorry
- aus_z1300
- Elite Member
Time to create page: 0.166 seconds
