Welcome to the Kunena forum!
Cruzinimage big bore kit, who's tried them?
- Petez13
Re: Cruzinimage big bore kit, who's tried them?
10 years 4 months ago
Hi Rob,
Good to know the bike runs well with the cruzinimage big bore kit.
Did you use any sealant with the head gasket?
And do you have the measurements needed for the re-bore?
Thanks Pete.
Thanks Pete.
- rob
- Senior Member
You would need an engineering shop to measure the pistons prior to rebore. If i recall you are left with about 2mm thickness on the barrel sleeve. The engineering shop i used made up a sleeve used around the the bottom of the piston sleeve to avoid any complications whilst boring and to stop any metal flex during the boring process.
Not sure but i think the pistons are 67mm diameter
Hope this helps
Regards
Rob
Hope this helps
Regards
Rob
- rob
- Senior Member
Do not use any type of sealant with head gasket.
Cheers
Rob
Cheers
Rob
- Petez13
Thanks Rob,
I'm suprised you say dont use any sealant
on the head gasket, everyone has always said on none genuine head gaskets to use sealant. But your talking from experience so that's interesting,
By the way, I've just seen the pics of your bike, Love it, very tasteful changes you've made.
cheers Pete.
cheers Pete.
Time to create page: 0.160 seconds
