kz1300 banner
Welcome to the Kunena forum!
Newb Here
  • YoungBloodOldBike
  • YoungBloodOldBike's Avatar Topic Author
  • New Member
  • New Member
Re: Newb Here
10 years 5 days ago
#12034
And some more...
Why buy what you can get for free!
  • trikebldr
  • trikebldr's Avatar
Re: Newb Here
10 years 5 days ago
#12041
Welcome to the site! From your pics it looks like a good set of guages and and a cleanup/polish job would make that bike look good! Most of your work looks like it will be with the carbs to make it run.
  • YoungBloodOldBike
  • New Member
  • New Member
Re: Newb Here
10 years 4 days ago
#12064
Yeah I was thinking a nice digital gauge cluster. They are pricey at $300 but I would rather spend that on a new one then spend the same amount on one off eBay that who knows if even works properly. Hopefully all I have to do is some aesthetic stuff and the carbs, but my luck is never that good. Going to start by doing a compression check on the cylinders to make sure we dont have any leaks, a bent valve would ruin my day for sure.
  • Kawboy
  • Kawboy's Avatar
Re: Newb Here
10 years 4 days ago
#12065
It's only showing 10K on the clock so I would imagine that mechanically you SHOULD be fine, but prudence would have you check everything. Check check check................
  • AERIAL0
  • AERIAL0's Avatar
  • New Member
  • New Member
Re: Newb Here
10 years 4 days ago
#12072
Welcome to the forum and enjoy. B4 you do a compression check, pour a little oil into the cylinders and turn over. Makes a big difference re the readings. All the best with your restoration, and remember Rome was not built in a day and a Z1300 restoration is the same. Parts are the problem :whistle:.
