kz1300 banner
Welcome to the Kunena forum!
How fast?
  • Phil
  • Phil's Avatar
  • 1984 ZG1300-A1 DFI
Re: How fast?
9 years 8 months ago
#14165
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
  • Lifelong Rider Suffering Through MBD
Re: How fast?
#14166
Phil wrote:
That would be the answer! Thanks Phil!
  • Phil
  • Phil's Avatar
Re: How fast?
#14168
I have a confession to make in that it wasn't me :blush: :P The guy who took that pic says that since having the rear wheel of his 1300 widened, because modern tyres have a lower profile it's lowered the overall gearing. He says that on stock gearing it used to pull an indicated 150 (which is, I guess, a true 140) :whistle:
  • Kawboy
  • Kawboy's Avatar
Re: How fast?
#14169
KZQ wrote:
I've wound out a CBX to 135mph and I can tell you , you wouldn't want to let go of the handlebar at that speed on a 700 lb bike let alone take your eyes off of the road, so I can't imagine what digit this guy snapped the picture with. :blush:
  • roadhazard
  • roadhazard's Avatar
  • Junior Member
  • Junior Member
Re: How fast?
#14171
Hey Phil, you're out of gas. :)
1980 Kz 1300 b2 touring
1980 kz 1300 A2
  • dogfight
  • dogfight's Avatar
  • Junior Member
  • Junior Member
Re: How fast?
9 years 7 months ago
#14493
You do know that it's a 5 speed transmission, right? Maybe check your clutch adjustment or plates, especially the steels. Old ones get hot and are hard to grab if they warp. Check them on a flat block or a piece of plate glass. Even a few thou out can leave oil between the plates and cause slip and slop.
A dirty clutch basket can do the same by not allowing the plates to mate up properly. Same for a worn hub bearing or pressure plate or spring(s).
The answer is always inside.
Good luck with it and let us know what you find.
Tim (Dogfight)
Time to create page: 0.173 seconds
