Welcome to the Kunena forum!
On The Road Again......
- englishcw
- Senior Member
6 years 1 month ago
Well , not quite . After a Long Hibernation , Last M.O.T I can find is 1991 , My Z1300 , owned since 1987 has just fired up . 73 , riding since I was 16 . Also own / ride / fettle my Two Harleys . Location , Birmingham U.K. After seeing some of theZ1300's on Dreads site [ many Years ago ] , one being Purple ? , and Owned I think by Pete F , a Memeber here .Decided to refresh My Z. Of course , life etc , as always , took a turn . I have fitted a Dyna Igniton , bought many Years ago , and I have just this minute finished re-wiring the Bike with a Motogadget Unit . One problem I have , is a rattle on the left side , top end . When the engine was out of the frame I took it to a Respected Motorcycle Mechanic to have the valve clearences checked , I now have to remove cam cover to check myself . A little long winded , I know , but having it fire up , I got a little excited , Thanks for having me , clive . P.S. PeteF [ Sure it is you ] , The gauges and Idiot Lights I purchased from you all those Years ago , look a treat , and work well , Thanks .
- englishcw
- Senior Member
Re: On The Road Again......
6 years 1 month ago
Up - Date . Noise / Rattle. In my haste to fire the bike up , I had neglected / forgot to replace several bolts . nowhere serious. I had started to replace the bolts that hold the Air Suction Plates on the Cam Cover with new ones , and had run out of bolts , so the right hand side plate had just one bolt holding it in place . Realised before I strted to dismantle the Cam Cover .
- biltonjim
6 years 1 month ago
Can you post some photos please?
Glad your rattle was nothing serious.
What’s your story of how you came to choose and buy a 1300? And your impressions of it?
- Phil
- 1984 ZG1300-A1 DFI
6 years 1 month ago
I used to frequent Dread's Z1300 site too, as did Pete F. He runs a Facebook Z1300 group now.
- McBoney
6 years 1 month ago
I am thinking of using a Motogadget unit on my build, I'd be interested to learn of any tricks to do it properly...
Paul
Paul
Six-Pot-Cafe in the making...
- englishcw
- Senior Member
6 years 1 month ago
Hi Paul . no real tricks , they come with good instructions . I mounted the unit where the old fuse box was mounted . One trick , I did mount a seperate fuse box , so that the Fan had a constant supply . Although the Motogadget does have an Aux terminal that holds the power on for 1 minute .
The following user(s) said Thank You: McBoney
Time to create page: 0.160 seconds
