Welcome to the Kunena forum!
GPZ900R Petrol Tap Kit ........QUESTION ?
- strate6
- On An Adventure Before Dementia ! !
12 years 1 month ago
For those who have carried our the GPZ (ZX)900R Petrol Tap Conversion, can you please help me ?
When I bought the tap, I stripped it to make sure all was well inside & it looked ok but once I tried using it, there was a leak from around the flap that selects ON/PRI/RES. It must be the large o ring that sits in the recess on the flap.
Judging by the condition of the screw heads & internals & believe this tap has not been opened up before & was from a low mileage bike.
No problem.........I just bought a kit online.
This is shown below.
Problem is I cannot find where the TWO large o rings supplied actually go.
ONE of them obviously fits in the recess, but I cannot work out what the other is for as my tap ONLY has one such o ring inside.
Mine is shown below.
A Large Black Seal OK
B Large O Ring for Flap OK
C Thin Wavey Metal Washer (goes between outer face of flap & cover plate with 2 screws.
So can anyone tell me where the OTHER large O Ring goes ??????
Pete F
UK
Pete F
UK
- Toddh
Re: GPZ900R Petrol Tap Kit ........QUESTION ?
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
- strate6
Yep................it only shows one o ring on there too !!
Pete F
Pete F
- KZQ
- Administrator
- Lifelong Rider Suffering Through MBD
12 years 1 month ago - 12 years 1 month ago
Isn't the other large O ring to be bent into the oval seal groove at the tank?
Last edit: 12 years 1 month ago by KZQ.
The following user(s) said Thank You: strate6
- strate6
Ahhh, You just maybe right Bill.
I guess that would make some sort of sense & be cheaper than making a contoured ring.
Will see if it fits that oval groove tomorrow.
Thanks again
Pete F
Thanks again
Pete F
- kwak1261
Looks very similar to a GS1000 fuel tap. 44mm bolt hole centre
you get a shaped oval O ring for the base in a overhaul kit.
i have one of these taps so i could take a few measurements if needed.
also came with 50mm bolt hole spacing.
Ian
Ian
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
Z1261J GS1000S
Vmax1200 XT500
Last edit: 12 years 1 month ago by kwak1261.
Time to create page: 0.186 seconds
