kz1300 banner
Welcome to the Kunena forum!
Hello from down-under, Coffs Harbour.
  • zed_thirteen
  • zed_thirteen's Avatar
Re: Hello from down-under, Coffs Harbour.
8 months 2 weeks ago
#34059
That doesn't look like a B2-Touring (I own one) - the rear end and luggage frame aren't B2 and the B2 had split front and rear seats. I suspect this was a Vetter dressed bike
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
  • biltonjim
  • biltonjim's Avatar
8 months 2 weeks ago - 8 months 2 weeks ago
#34060
Ah yes, zed-thirteen- I beg your pardon.  It was the side cover that threw me.  Looking again, the fuel tank is not the large capacity type as fitted to the B2, and didn’t the B2 have a slightly different front mudguard?
Yes, likely it was Vetter equipped -
www.vetterowners.com/threads/1980-kawasaki-kz1300.574/
Last edit: 8 months 2 weeks ago by biltonjim.
  • zed_thirteen
#34061
B2 front mudguard is different at the lower rear - has a shaped lip/protrusion (not sure how to describe it
1980 CBX1000-A
1990 ZZ-R1100 C1
  • Raidermoto
  • Raidermoto's Avatar Topic Author
  • New Member
  • New Member
#34063
Cheers Jim, the B2 member (Zed 13) has reached out & offered a stack of knowledge.  I know zip about these old ladys so sounds like we're in the right spot.  Not a Bimbo in the back ground, it's a Rau (Manfred Rau).  We used to design & build custom small bore bikes, 400 to 750cc, then we wanted something for real riders so after a lot of searching we stumbled on the Manfred Rau story and decided they were excellent bases for us to produce large capacity bikes.  We imported them as Raider Rau's, & using a Bimota type system that one's an RY1.1 (Raider Yamaha 1100cc).
I'm a Bimota diehard, although for me they can/should only have Ducati engines, although I am considering a KB998 out of fiannly accepting I'll never have enough funds to commission them to build me a DBV4R :)   My daily's a DB9 but there's a few others.     Apologies to all if I shouldn't post non-KZ images?
  • Raidermoto
  • New Member
  • New Member
8 months 1 week ago
#34064
Hi Zed, thanks for the info, so is there a consensus on exactly what it is?  Doesn't makes a great difference to us in respect to making her a grand old tourer again, but I'd like to inform the owner for his knowledge. I haven't seen exterior pics of the fairing so I will get some, but the inside finish of the faring is different on this one, it has 3 toggle switches & a separate key in lefthand side, some type of additional security system I think.  The top box is definitely same as the one in the link, almost identical seat and looking at various mounting brackets I'd wager it's a Vetter.
Am I correct in assuming Vetter was a US based accessories company that supplied Kawaka US with what effectively OEM accessories?
  • biltonjim
8 months 1 week ago
#34070
Thanks for the information on the Rau bikes, and for the photo of your DB9 - that’s a fabulous looker, so rich in design detail. The Italians are masters at such things.
The following user(s) said Thank You: Raidermoto
Time to create page: 0.164 seconds
