kz1300 banner
Welcome to the Kunena forum!
clutch swap
  • candp
  • candp's Avatar Topic Author
  • Junior Member
  • Junior Member
clutch swap
11 years 7 months ago
#4758
hay guys!just got a 84 voyager trike with toyota rearend.needs clutch.was trying to find z1300 clutch swap with voyager1300 article,
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
  • Lifelong Rider Suffering Through MBD
Re: clutch swap
11 years 7 months ago - 11 years 7 months ago
#4759
The Voyagers use a seven plate clutch verses the nine plates on a Z or KZ. The swap is simple except that you'll need two extra steel plates, a clutch basket and a clutch cover from a Z.
Bill
Last edit: 11 years 7 months ago by KZQ.
  • candp
  • Junior Member
  • Junior Member
Re: clutch swap
#4765
can this be done pulled from rt side,what about gear on other end the chain,putting that back on?thks
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: clutch swap
#4774
Yes it can all be accomplished from the right side of the engine. You'll need to fabricate a tool to prevent the clutch basket from turning. If I understand your question, the countershaft sprocket/gear need not be secured to remove the clutch.
Bill
  • candp
  • Junior Member
  • Junior Member
Re: clutch swap
#4776
special tools, clutch hub holder,extender,pusher.reread shop book,what thru me off was how they come from ebay wrecking yards.friction plates steel plates springs in a outter basket,with barring and splined coupler on very back of basket.seems install will be without that?
  • candp
  • Junior Member
  • Junior Member
Re: clutch swap
#4779
hay bill got all the kawa tools 1671,1039,and 305 105.00 shipped i am going in!
Time to create page: 0.169 seconds
