kz1300 banner
Welcome to the Kunena forum!
head bolt sequence ??
  • bobber-edd
  • bobber-edd's Avatar Topic Author
  • Premium Member
  • Premium Member
Re: head bolt sequence ??
11 years 5 months ago
#5076
yes i read it wrong doh!!!ft and in i missed that
zed 13 1979 A1 model
  • Lucien-Harpress
  • Lucien-Harpress's Avatar
#5077
Final values for the nuts are going to be 29 ft-lbs.
Final values for the bolts are going to be 87 inch-lbs, OR 7.25 ft-lbs.
The important thing is to NOT try to set them all at the final torque settings right away. Work up to them. Set all the nuts at 10 ft-lbs. for the first pass, then 20 ft-lbs. for the next, then 29 ft-lbs. for the final torque. Same with the smaller bolts- exact settings aren't important until the last one, just so you "sneak" up on it gradually.
The following user(s) said Thank You: bobber-edd
Time to create page: 0.176 seconds
