kz1300 banner
Help!!
  • jbleavins
  • jbleavins's Avatar Topic Author
  • New Member
  • New Member
Help!!
9 years 11 months ago
#13324
Forgive my ignorance but I need to know what goes in this reservoir. Just bought this bike and it runs out strong but this res is plumb dry. Is it supposed to be? Right in the middle of picture.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Help!!
#13326
That reservoir is part of the cooling system. You can download a manual from the home page of this site.
Welcome to KZ1300.COM
KZQ
The following user(s) said Thank You: jbleavins
  • jbleavins
  • New Member
  • New Member
Re: Help!!
#13331
So....should have antifreeze/water mix in it?
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Help!!
#13341
Yes 50/50. I also use the wetting agent additive.
Bill
  • BigSix
  • BigSix's Avatar
Re: Help!!
#13343
All,
to my understanding this is the compensation tank for the colling system, means that it should be half full/empty as standard. Once the bike is warm it might be a bit fuller, once the engine cools down it will suck in whatever it needs from this little tank.
If you would fill it up to the top the engine would press out some of it when hotter, so you'd better just do half of it.
regards,
Holger
Z1300 A1/ KZT30AG built 1979
frame KZT30A 004285
engine KZT30A 000288
Moderators: dcarver220b
Time to create page: 0.165 seconds
