1982 KZ1300 rescue and rebuild
- stocktoy
Re: 1982 KZ1300 rescue and rebuild
7 years 8 months ago
Hi Stan, did you pre soak the clutch fiber plates for a least 24 hours in oil before you installed them. I know rebuilding automatic tranny's that we had to soak the plates for 24 hrs in tranny fluid to make sure they were fully saturated with oil.
- StanG
- Banned
Oh yes. That was well taken care of, plastic bag and oil. It's 1000 km now, either way they are well saturated by now anyway. I think it might be just the adjustment. Will see and report.
- StanG
- Banned
I am still thinking the steel discs might generate unwanted oil layer. First will play with the adjustment, then dig in deeper. The good thing is it's a relatively simple and area pin pointed issue.
- scotch
After a few hundred K. on my new clutch I did an adjustment on the push-rod stud and lock-nut. Then a minor adjustment on the cable, itself. Didn't have any issues - just some maintenance to account for the new friction-plates settling in.
Always High - Know Fear !
- StanG
- Banned
Yes, the clutch and carbs adjustments are on the list. Just trying to find a time and place to do it.
- Bucko
Different bike but my 900F is susceptible to clutch slip if I don't have the 'throw out lever' (if that's what it's called) adjustment on the clutch cover set properly (it's a similar configuration to the 1300 clutch except it's internal to the clutch cover - accessed through a screw-in plug)
Moderators: dcarver220b
Time to create page: 0.202 seconds
