Rear wheel swap
- Slim4ever161
- New Member
Rear wheel swap
5 years 6 months ago
Hey y'all, can anyone tell me if the z 1300 17" rear rim will work on the voyager 1300? My Hayabusa rear shock and linkage arrived yesterday and before I start mocking it up I wanted to get the back tire all situated
Thanks
Slim.....
Thanks
Slim.....
- Bar
- Elite Member
Re: Rear wheel swap
Hi Slim,
from what I can tell by looking at the part numbers and at the parts it will not work (I'm comparing to KZ)
I believe you will need to change also the Drive shaft and the shaft
as much as I know the the shaft gearing is different
I want to believe the shaft length is the same and the drive shaft size and mounting bolts to the swing arm will be the same
I also have 1984 Voyager and too bad I didn't think about it before
1984 Kawasaki Voyager
2002 Honda CBR954
2002 Honda CBR954
The following user(s) said Thank You: Slim4ever161
Moderators: dcarver220b
Time to create page: 0.157 seconds
