kz1300 banner
Fuel and Temperature Gauge
  • Bar
  • Bar's Avatar Topic Author
  • Elite Member
  • Elite Member
5 years 2 months ago
#28755
the new speedometer gauge I'm using have the option to connect fuel and temperature gauge
when I connect the water temperature gauge it is going to the red quick after the bike is on for few min
the water temperature thermostat is new
the fuel gauge is not working at all, I am not sure if the issue is the fuel gauge or the speedometer
anyone have an idea how to adopt the original water temperature thermostat to work with the new gauge, I'm thinking I need to add a resistor ??
for the fuel gauge, how I can test it first to make sure its working
I am also thinking to add external temperature and fuel gauge if they will not work as part of the speedometer, any suggestion ?
Thank You
Eran
1984 Kawasaki Voyager
2002 Honda CBR954
  • Kawboy
  • Kawboy's Avatar
Re: Fuel and Temperature Gauge
#28756
Eran,
You started a new post instead of continuing on with a build post on your project, so it doesn't help.
If I remember right you're installing a M unit on the bike?? and trying to marry in the existing sending units?? Can you update this topic please? maybe we can help.
KB
The following user(s) said Thank You: dcarver220b
  • Bar
  • Elite Member
  • Elite Member
#28762
move the post to my project post
2002 Honda CBR954
  • Phil
  • Phil's Avatar
  • 1984 ZG1300-A1 DFI
#28767
Have you still got the original instrument voltage regulator in circuit? Just a thought.
Moderators: dcarver220b
Time to create page: 0.184 seconds
