kz1300 banner
Backfiring
  • Tzrplzr2
  • Tzrplzr2's Avatar Topic Author
  • Junior Member
  • Junior Member
Backfiring
4 years 6 months ago
#29975
Bought a bike that had been sitting for 17 years! 1984 zn1300 A2. All hoses have been replaced, got the fuel pump spinning again, rebuilt the switches, kill switch was an issue causing it not to even try and start. Now it runs and sort of idles but especially when i twist the throttle a bit it pops and backfires? Any ideas? Any help would be great!
Alan
  • scotch
  • scotch's Avatar
Re: Backfiring
4 years 6 months ago - 4 years 6 months ago
#29978
First thing that comes to mind is a vacuum leak.  Whether carb'd or F/I , a gasket between the holders and the manifold will eliminates the vacuum leaks there.
Sand the holder surface as shown and add the gasket (dry)
Always High - Know Fear !
Last edit: 4 years 6 months ago by scotch.
The following user(s) said Thank You: Tzrplzr2
  • Kawboy
  • Kawboy's Avatar
Re: Backfiring
#29980
Scotch is on the right track. Lean fuel mixtures cause backfiring. After 27 years of sitting, gaskets and rubber components dry out and leaks can occur. Also, check the rubber flanges that hold the throttle bodies for leaks between the flange and throttle bodies.
1.
if no leaks are found, 2 things come to mind.
Fuel injectors have been stuck from 27 years of sitting in stale fuel and likely need cleaning.
2. Throttle position sensor is not giving a solid signal back to the DFI Computer. It's a simple rheostat and may need a bit of contact cleaner to smarten it up.
Last edit: 4 years 6 months ago by Kawboy.
  • Tzrplzr2
  • Junior Member
  • Junior Member
Re: Backfiring
#29982
Thanks for the info pulled all the injectors last night to get them cleaned, but did not think about the t p s
Alan
  • biltonjim
  • biltonjim's Avatar
Re: Backfiring
#29983
When somebody says the engine is backfiring, to me that suggests an explosion of unburnt fuel in the exhaust system.  Is that what is happening here?
  • Tzrplzr2
  • Junior Member
  • Junior Member
Re: Backfiring
#29985
Yes I believe so as it is also throwing Flame! The exhaust does not smell rich, if anything it smells a little lean. So I thought I'd post on here get all the ideas while I've got it taken back apart try to cover them all. my first Kawasaki and I've never had one to revive that has set this long.
Alan
Moderators: dcarver220b
Time to create page: 0.160 seconds
