rear brake
- BigSix
rear brake
2 years 1 week ago
Hi guys,
I recently had me rear-brake cylinder revised by an expert. Got it back, mounted it back on, vented the line and cheked everything. Looked good.
I then decided to do a short ride to check. Bike on the main-stand, engined started. I then noticed that the rear wheel did not turn, as it usually does in neutral. I feared that there is an dditional issue with the rear-brake and did a short trip to check if the rear brake disc gets hot (I used to have an issue before the rear brake cylinder had been revised).
Any ideas, thoughts, advice ?
Thanks, Holger
Thanks, Holger
Z1300 A1/ KZT30AG built 1979
frame KZT30A 004285
engine KZT30A 000288
frame KZT30A 004285
- Ted
Re: rear brake
2 years 1 week ago - 2 years 1 week ago
Did it get hot? Can you spin it freely on the centerstand? If it doesn't move freely, your calipers are sticking and need cleaning. It's pretty easy to do and disassembly is in the service manual.
For many years I was intimidated by brake systems, then I retired and decided to learn. I learned that it is very easy and it's embarrassing to think what I used to pay other people to repair my brakes over the years, but that also applies to other repairs and tuneups for that matter.
1981 KZ1300, '98 Suzuki GSF1200S, Honda CL360, Honda CB350G,'11 Honda CBR250, '75 Honda CL360, '00 Honda XR100R
Speak softly and mount a fast bike.
Last edit: 2 years 1 week ago by Ted.
- Kawboy
Re: rear brake
2 years 1 week ago
One or both of the pads are dragging on the rotor. Since it's a 2 piston caliper, the caliper is fixed mounted and not floating on pins.
First try to pry back the pistons back into the caliper. They should move back fairly easily. if they don't retract, it maybe because the master cylinder linkage is not adjusted right. There's a relief port in the master cylinder that is exposed when the master cylinder piston is retracted and that port relieves the brake fluid pressure on the caliper back into the reservoir. If you can't pry back the caliper pistons, first try breaking a joint in the brake line and then try retracing the pistons. if then they retract, you know that the relief port in the master is not open. and you need to look at the linkage adjustment.
if the piston are stiff to retract, then the pistons may be partially seized in the calipers and need servicing.
The following user(s) said Thank You: BigSix
- BigSix
Re: rear brake
2 years 1 week ago
I have sorted it out. Took a longer ride. Engine got hot, brake disc stayed cool. Just as I wished for.
Thanks guys.
Holger
Thanks guys.
Holger
frame KZT30A 004285
frame KZT30A 004285
Moderators: dcarver220b
Time to create page: 0.177 seconds
