fuel issue
- paulb
- Elite Member
fuel issue
11 years 3 months ago
Hi guys
I have had trouble starting my bike at the moment it seems to be running very rich which usually results in it starting on 4 cylinders because a couple of the plugs get fouled once I dry out the plugs it runs on all six but yesterday I struggled to get it going so I pulled out the air filter and found fuel pooled in the bottom of the air filter housing any ideas where it could come from and could it be connected to the running rich issue, bike was running fine previously
thanks for any help
Paulb
thanks for any help
Paulb
- Kawboy
Re: fuel issue
Sounds to me like you have a float stuck or sunk (saturated with fuel) and the fuel is pissing back up and out of the main jet into the carb, then into the air box. Be careful here because it could just as easily have flowed into the intake and down the cylinder. If that happens you could get a hydraulic lock and bend a connecting rod.
- paulb
- Elite Member
Re: fuel issue
Thanks Kawboy
if I take the bike for a run presumably it will free it up
- stocktoy
Re: fuel issue
I think that if the float has lost its buoyancy and is absorbing fuel (like a sponge so to speak) no amount of riding will stop it from riding low in the float bowl and bypassing fuel. if it is a float you will to test the buoyancy of all your floats either by side by side comparisons in a container of gas ( to note one floats noticeably lower then the others) or sometimes you can get an indication by pressing a fingernail into an edge of a float and see if it leaves an indentation or wetness.
Hope this helps
Hope this helps
- AERIAL0
- New Member
Re: fuel issue
I agree with Kawboy. Drop your float bowls and check the floats. Had the same problem on other bikes and just by shaking them your able to determine if leaking or place in petrol and look for the bubbles. Take all plugs out and turn over as the last thing you need is a a lock up :ohmy:
- Lucien-Harpress
Re: fuel issue
11 years 3 months agoPlease Log in or Create an account to join the conversation.
Moderators: scotch
Time to create page: 0.175 seconds
