kz1300 banner
Cannot remove the idle jets
  • Akz1300
  • Akz1300's Avatar Topic Author
  • Junior Member
  • Junior Member
10 years 9 months ago
#7749
Hi all, I have a kz 1300 1979 very early model import, only had a year, carbs are off and stripped and been in my ultrasonic cleaner, but I cannot remove the idle jets! They are loose but just won't drop out, how do I do it? Many thanks.
  • bassie20
  • bassie20's Avatar
  • Senior Member
  • Senior Member
Re: Cannot remove the idle jets
#7751
I have the same problem, I guess the heads are a little deformed due to a screwdriver that didn't fit.
I leave them as they are, they are open.
drilling them is the only way i can think of. :S
  • scotch
  • scotch's Avatar
10 years 9 months ago - 10 years 9 months ago
#7757
The reason these jets will not come out is due to the incorrect size and shape of the driver used to install them the last time they were out. Do some searching in previous "Carb rebuild" topics and you'll see several pictures of the 3 drivers made specifically for the idle-jet, idle-jet cap and main-jet. The critical one being for the idle-jet itself. The slightest burr or deformation will cause this issue.
You have stated the jet is loose. The carb must be stripped of parts. If you have an idle jet as a sample, grind an appropriate sized driver to fit (see previously mentioned photos). The fit is very important for both removing and installing. There are more details in that write-up.
Apply penetrating oil to the jet threads and using "the modified" driver, screw the jet in and out repeatedly until your hand cramps ! The more times the better ! DO NOT TIGHTEN. When you feel the jet start to make contact at the bottom - STOP. This may take several attempts. By repeatedly threading in and out the burr/deformation will be reduced. Over a large card-board box and holding the carb so the idle jet will fall into it, apply full air pressure to the idle-screw port. The idle-jet should blow out.
If not: With the jet loose, heat the carb body and apply air pressure, again. Keep in mind there are seals on the throttle shaft. Common-sense here for the heating! 200f is enough ! See the same article for how I heated carbs using a card-board box and a small electric heater. ( common-sense with this too !)
if not, keep repeating.
Drilling is the last resort. Drilling will ruin the jet and very probably ruin the internal threads.
Burrs can be removed from the jet with a jewelers file. If you don't have one - buy one ! When cleaned of burrs and when Re & Re'd with the correct fitting driver, they jets will fall out, next time.
Always High - Know Fear !
Last edit: 10 years 9 months ago by scotch.
The following user(s) said Thank You: biltonjim, Akz1300
  • Lucien-Harpress
  • Lucien-Harpress's Avatar
#7758
I had the same problem on my bank. Ended up having to drill the jet and hit it with an easy-out. My issue was that the top (where the screwdriver slot is) was jacked up, and there was no way the jet was coming out in one piece. Broke my heart.
Probably the best advice scotch gave is to sacrifice a screwdriver to get the proper shape needed to screw in and unscrew the jet cleanly. You'll have to grind it down quite a bit, but it's worth it.
Last edit: 10 years 9 months ago by Lucien-Harpress.
The following user(s) said Thank You: Akz1300
  • Akz1300
  • Junior Member
  • Junior Member
#7759
Screwdriver all ready formed, will try the screw in & out technique, will check where to blow in air as advised, this is a fantastic site and gives you confidence to have a go! Cheers all.
  • Craig
  • Craig's Avatar
#7760
I had the same problem. After following one of Scotch's previous threads (as stated above), I still battled. At the end, I used compressed air and a precise smear of super glue on the custom screw driver tip. Placed the screw driver into the jet, held it firmly for 10 or so seconds and then slowly unscrewed it out with the aid of the compressed air. I wasn't using the idle jets again, so wasn't fused about the use of the super glue!
Moderators: scotch
Time to create page: 0.173 seconds
