Revs slow to drop.
- McZed
- Elite Member
Revs slow to drop.
10 years 7 months ago
I am trying out a spare set of carburettors on my bike. Stripped and cleaned all the jets, it seems to be running ok but when I rev it and then close the throttle, the revs are slow to drop back down to tick over. I have checked the carb rubbers are properly tightened to stop any air leaks and they seem ok.
Any helpful suggestions would be greatly appreciated.
Z1300 UK
- scotch
Re: Revs slow to drop.
10 years 7 months ago - 10 years 7 months ago
McZed - presumably you've ensured a slight amount of slack in the throttle cable.
Check your fast idle/choke adjustment. (Choke cam and roller) The manual is very specific about this adjustment. If it is not adjusted correctly the small roller will ride on the fast idle/choke cam and not on the idle stop which is adjusted separately by the long adjusting screw between the left and center carbs. Details on page 50 of the manual.
Always High - Know Fear !
Last edit: 10 years 7 months ago by scotch.
The following user(s) said Thank You: McZed
Moderators: scotch
Time to create page: 0.149 seconds
