kz1300 banner
float level plate how many mm must it be bent pls
  • Brenden31
  • Brenden31's Avatar Topic Author
  • New Member
  • New Member
10 years 9 months ago
#9298
Float level plate how many mm must it be bent pls help I'm in south africa.
  • Lucien-Harpress
  • Lucien-Harpress's Avatar
Re: float level plate how many mm must it be bent pls
10 years 9 months ago - 10 years 9 months ago
#9301
Tough to say. General rule of thumb is to make the bottom of the float parallel to the bottom of the carb body (when there is no weight on the float needle valve). However, a more accurate way to check it is with the "wet" level- attach a clear tube to the drain hole, loop it up to above the level of the bowl, fill with fuel, and measure the fuel level from the bottom of the carb body. [strike]I believe it's supposed to be 16-19mm below the carb body,[/strike] but I'm probably wrong. (Yes, I am.)
Check the main page- we have full downloadable manuals that walk you through the whole process.
Last edit: 10 years 9 months ago by Lucien-Harpress.
  • Kawboy
  • Kawboy's Avatar
#9303
See page 170 in the manual. 6.5 - 8.5 mm below the bottom edge of the carb body.
The following user(s) said Thank You: Brenden31
  • Brenden31
  • New Member
  • New Member
#9307
Kawboy wrote: See page 170 in the manual. 6.5 - 8.5 mm below the bottom edge of the carb body.
. Is there maybe a image
  • Kawboy
  • Kawboy's Avatar
#9313
The manual is available from the bottom right hand corner of the home page. Then check page 170 and yes, there's an image.
Moderators: scotch
Time to create page: 0.162 seconds
