Choke lever won't stay in place
- charlie9670
- Elite Member
9 years 7 months ago
My carbs are performing extremely well after strip, clean and new parts even though I've not done any balancing etc. It starts straight away on full choke but chugs a little on 1000rpm, after a few seconds I drop the choke lever half way down and it sits at 2000rpm running smoothly to warm up but I have to hold the lever in place as it snaps straight down if I let go. Not sure if this is normal or what I can do to remedy it so I can leave the bike on half choke for a minute to get warm and then tickover with the choke off?
- Kawboy
Re: Choke lever won't stay in place
9 years 7 months ago - 9 years 7 months ago
Best guess here is that you're missing one of the washers or the spring on the retainer bolt that holds the choke lever. Under the head of that shouldered bolt should be a spring, then a plain steel washer, then a duracon washer (fibre washer) then the choke lever, then another plain steel washer.
I like to use www.partszilla.com for exploded assembly drawings and part numbers.
This should help www.partzilla.com/parts/search/Kawasaki/...ETOR+ASSY/parts.html
Last edit: 9 years 7 months ago by Kawboy.
The following user(s) said Thank You: charlie9670
- charlie9670
- Elite Member
Just checked it and the screw wasn't tight enough..simple as , bit like myself had a screw loose :S thanks for the reply.
Last edit: 9 years 7 months ago by charlie9670.
- zed_thirteen
Sometimes the shoulder on the shaft of the screw can tighten against the choke lever when you install it instead of the carb body - so it feels tightened.
Then when you move the choke lever it drops into the arc travel recess and becomes loose.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
- charlie9670
- Elite Member
There is only the smallest amount of a turn between being loose and locking up but it's working now so I'll have a closer look when it comes in for the winter, I've got a spare set to rebuild as well so all bases covered carb wise...hopefully!
Moderators: scotch
Time to create page: 0.159 seconds
