84 zn1300 air filter box
- cartdoc
- New Member
9 years 5 months ago
how do you remove the bottom half of the air filter box for cleaning.
- cartdoc
- New Member
Re: 84 zn1300 air filter box
seems like there is no room between top rear motor mount and frame.
- cartdoc
- New Member
I wont tell you who do not know just how much fun it is removing the complete air box from an 84 zn1300.If kawi would have shortened this box by a mere one half inch it would have been no problem...that's all I got..squirals built a nest in the bottom!!
- hillsy
If the Voyager has the same set-up as the Z13 then you need to remove the coolant overflow tank as it is connected by a press in grommet at the back.
Moderators: scotch
Time to create page: 0.176 seconds
