kz1300 banner
Stuck fuel valve - revisited
  • scotch
  • scotch's Avatar Topic Author
8 years 4 months ago
#18105
Thought it timely to bring this up again as it's buried three+ years ago and addresses stans query regarding this problem.
www.kz1300.com/index.php/forum/carburato...k-fuel-valve-petcock
Always High - Know Fear !
  • Toddh
  • Toddh's Avatar
Re: Stuck fuel valve - revisited
#18107
If anyone has to reassemble theirs, make sure the phonelic cone (the part with the holes in it) goes back in the way it came out. Assembled mine onetime 180 off to where the holes did not align properly. When I hit reserve on the next ride guess what, no fuel flow............
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
  • scotch
#18108
A valid and IMPORTANT point Toddh ! An over site on my part ! Thank You ! (I made the same mistake - once! :whistle: )
  • Bucko
  • Bucko's Avatar
#18121
I scratched my head over this one myself. If you look down into the tap from the tank side with the cone inserted you can rotate it around to where it make sense according to the tap position stamping on the cover.
Moderators: scotch
Time to create page: 0.195 seconds
