kz1300 banner
'79 A1 Nylon piston needle holder 130911056
  • RChaloner
  • RChaloner's Avatar Topic Author
  • Elite Member
  • Elite Member
7 years 9 months ago
#20313
Hello folks,
Are these available anywhere?
(it's the plastic part that sits above the main needle inside the slider piston and held in with the circlip)
I have one with a broken upper slot flange.
M-a-y be repairable, very narrow long self-tapper & washer / spacer to recreate the same amount of clearance, but replacement of course much easier!
May be about to hear this is one of those holy-grail items..?
Partzilla says it's fitted to multiple models up to '82 A4, but I've read elsewhere that a lot of later models have multi-needle slots for adjustment, which this '79 doesn't have, so not too sure about swaps.
Richard.
1979 KZ1300 A1
1999 K1200LT - now sold, I like them however was nearly as big as my X5 but no faster.
  • scotch
  • scotch's Avatar
Re: '79 A1 Nylon piston needle holder 130911056
#20316
It's not repairable ! Best bet is to post a picture and see if someone has an un-serviceable carb that this part can be removed from. Should be the same for all years of carb'd 1300's regardless of needle style (single or 5-slot)
Always High - Know Fear !
  • RChaloner
  • Elite Member
  • Elite Member
#20317
Ah I see the slots are in the (later) needles not the pieces around it.
I've attached a couple of pic's; in the first you can see the 'top flange (lowest in the picture), which slides into the carrier plate, has snapped off.
The second picture just shows (for reference( the foot that holds the needle down in the piston ass'y, with it's offset centre & dimples.
Any spares out there in Z-land??
1979 KZ1300 A1
Moderators: scotch
Time to create page: 0.162 seconds
