Mixture Screw Caps ??
- strate6
7 years 7 months ago
Cannot remember if it was on this site, but did someone once find a suitable little rubber or plastic cap to fit into the hole above the 6 Mixture Screws, to stop them getting full of crud ?
Thanks
Pete F
Thanks
Pete F
- scotch
Re: Mixture Screw Caps ??
Hi Pete ! For what it's worth - I wouldn't worry about these caps. Trying to remove any type of cap/plug will be difficult with the carbs installed. Especially if you just want to "tweak" the mixture. Consider soldering an "Allen-head" to the top of each screw and buy a Ball-end driver to fit. Adjusting the screws is SO MUCH EASIER!
www.kz1300.com/index.php/forum/carburato...crew-conversion#5527
Always High - Know Fear !
Moderators: scotch
Time to create page: 0.159 seconds
