Mixture screw rubber o rings
- StanG
- Banned
7 years 1 month ago - 7 years 1 month ago
Last edit: 7 years 1 month ago by StanG.
- StanG
- Banned
Re: Mixture screw rubber o rings
7 years 1 month ago
Missing these thin duracon washers (92022 - 1155) or damaged? I will have them (left: old, right: new)
- biltonjim
7 years 1 month ago
Have you had those washers specially made, Stan?
- StanG
- Banned
7 years 1 month ago
Yes and no. They are perfect size except the outer diameter, which I cut with a scissors to the correct size. What I need is to find someone local with lathe, make a 'bolt' to keep a bunch together, and machine the outer diameter at once. A very straight forward thing. If you just make a set of three it takes a few minutes and inconvenient, and I wasted a couple, but not a big deal. I just cut what I need and the rest is waiting for that lathe. 0r if I find a proper bolt from the get go, I will try doing it using my drill and a woodworking chisel.
- zed_thirteen
7 years 1 month agoAny chance this image could be edited to detail where each size is used?
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
- StanG
- Banned
Moderators: scotch
Time to create page: 0.170 seconds
