Lean Idle
- StanG
- Banned
Re: Lean Idle
6 years 10 months ago
Good to hear the positive results!
Just a couple thoughts. The counting of links is done the other way around, starting from the exhaust side. Another - how about getting a K&N air filter? It's reusable, cleans very nicely when you want, and lasts pretty much forever. It also lets more air through - might be a positive thing in your set up.
Stan
Stan
The following user(s) said Thank You: Daro
- Daro
Re: Lean Idle
Zed thirteen what air filter do you have? have you modified intake in any way? Having difficulty setting up the carbs, what is the problem? After almost instantly resolving my on-going problem with cams I'm sure the guys here will come up with something.
- Frank833
- Elite Member
Re: Lean Idle
6 years 10 months agozed_thirteen wrote: I have cruzin image 1370 kit on mine and am having difficulty setting up the carbs.
That is part of why I put an O2 Sensor and Gauge on mine. Still working out the idle mixture. Will move on after I get this close and let everyone know what I ended up with.
- Daro
Re: Lean Idle
Stan i don't know about this k&n filter, what i heard is that you should oil theme frequently so they actually filter properly? Have you got one? if yes, air fuel mixture how does it look like to compere to normal paper filter, you once wrote that you want to measure AFR on you bike did you do it?
- Daro
Re: Lean Idle
6 years 10 months ago - 6 years 10 months ago
Hi Frank what's the reading of you AFR gauge at 1000 rpm warm? My one is showing about 1 lambda. But I have 62mm pistons and standard intake with paper filter.
Last edit: 6 years 10 months ago by Daro.
- StanG
- Banned
Re: Lean Idle
6 years 10 months agoPlease Log in or Create an account to join the conversation.
Moderators: scotch
Time to create page: 0.153 seconds
