kz1300 banner
1300 stock fuel-valve (petcock)
  • stonehill
  • stonehill's Avatar
  • Junior Member
  • Junior Member
Re: 1300 stock fuel-valve (petcock)
7 years 3 months ago
#22734
Does it go straight?
  • Bucko
  • Bucko's Avatar
7 years 3 months ago - 7 years 3 months ago
#22737
strate6 wrote: Or you can always fit the VACUUM type petrol tap off a KAWASAKI GPZ900R,A4 /1988.
You will need to run a short vacuum pipe from your inlet track, which is easily done.
As this is a vacuum type tap, it stops petrol passing thru as soon as the engine stops running which is the reason they are fitted to modern bikes.
Pete F
UK
Thanks for posting Pete - that's a very good option. Do you happen to know if that tap fits a ZN model as well?
Last edit: 7 years 3 months ago by Bucko.
  • strate6
  • strate6's Avatar
  • On An Adventure Before Dementia ! !
#22761
Hi Bucko,
I cannot confirm that.
It will be down to the pitch between the 2 mounting holes and direction of the fuel pipe to the tap.
Regards
Pete F
UK
  • strate6
  • strate6's Avatar
#22762
Sorry mate...................what do you mean by "Does it go straight" ??
Pete F
UK
Moderators: scotch
Time to create page: 0.169 seconds
