Air temperature Sensor
- Bar
- Elite Member
Re: Air temperature Sensor
5 years 8 months ago
all from ebay.com
front master cylinder rebuild kit
323607796935
rear master cylinder new
232570520965
this is used master cylinder for newer model (2013 Voyager), will work as well
333058619356
front brake rebuild kit
263062959319
rear brake rebuild kit
401356415284
you can find many on ebay with the exception of rebuild kit for rear master cylinder
323607796935
232570520965
333058619356
263062959319
401356415284
1984 Kawasaki Voyager
2002 Honda CBR954
2002 Honda CBR954
The following user(s) said Thank You: ClintsMotorcycles
- ClintsMotorcycles
- Junior Member
Thanks for the replies. I need to decide if I want to take a chance on some used OEM stuff, some stuff from China or just buy some rebuild kits and spend the time doing them myself. I think I will have a couple of brews and think about it.
- Stiggy
No eBay APP ID and/or Cert ID defined in Kunena configurationIf your air temperature sensor is faulty and you cannot buy a genuine part, the sensor is a very common 2k NTC THERMISTOR. Like these..
Or as a trial replace the sensor with a 2.7k ohm resistor that will make the ecu believe the air temp is a constant around 25 deg c.
Hope this helps.
Hope this helps.
1985 ZG1300 dfi
1977 Z1000 a1 recent purchase, previously owned by myself 1979 ~2000
- Bar
- Elite Member
5 years 7 months agoClintsMotorcycles wrote: Thanks for the replies. I need to decide if I want to take a chance on some used OEM stuff, some stuff from China or just buy some rebuild kits and spend the time doing them myself. I think I will have a couple of brews and think about it.
when you buy used, you never know what you buy and may need to rebuild anyway.
rebuilding the calipers is easy job
2002 Honda CBR954
2002 Honda CBR954
- ClintsMotorcycles
- Junior Member
Rebuilding them is the conclusion that I reached as well. Thanks for the advice.
Moderators: scotch
Time to create page: 0.161 seconds
