kz1300 banner
Fuel Delivery Issues
  • dcarver220b
  • dcarver220b's Avatar Topic Author
5 years 5 months ago
#28585
My 79 A1 is delivering almost 4 of the 5 gallon or so tank.. Not good, and not confidence inspiring given I live in the sticks with few petrol stations around the best riding roads..
So, ‘Calibrated’ fuel gauge by filling tank, then draining 1 gallon per time. Surprising, I know, but the fuel gauge is completely non-linear. Imagine that.
Worse yet, after 4 gallons drained on a 5+ gallon tank.. no more fuel delivery. On the KZ, tank outlet and carb inlet.. maybe .5 inches..
Back in the day, ran a fuel pump and regulator. May have to re-think this idea. Problem back then was the regulator, at minimum, exceeded float/seat and would flood out.
Running Pingle petcock. Cleaned it up. Not running external filter or quick disconnect fitting externally to minimize flow resistance.
My tank will be sent off for professional cleaning and sealing.
Fuel line routing.. Is there consensus as to most efficient route? Mine currently goes between throttle cables, around valve cover to inlet. Using MotionPro fuel line,
it's very flexible and stout. 5/16" ID.
At the inlet.
  • dcarver220b
Re: Fuel Delivery Issues
#28586
At the 'bend around the corner, RHS of bike.
Gauge calibration and flow delivery test. Nothing after 4 gallons, even on reserve.
As she sits. Installed soft saddlebags. Looking to purchase some portable plastic gas cans to carry extra fuel.
Running a Pingel, found this Post on KZ1300.com
https://kz1300.com/index.php/forum/attachment/3023
https://kz1300.com/index.php/forum/attachment/3024
Think I'll try the KISS method(s) first...
Just rambling....
  • stocktoy
  • stocktoy's Avatar
#28597
In one of his many Carb topic posts Scotch has mentioned what routing he has found to be the best for him (can't put my finger in that post right now though)
  • scotch
  • scotch's Avatar
#28601
Routing is dependant on fuel valve style. Basically: Keep it short and avoid "Hills & Valleys".
Always High - Know Fear !
  • scotch
  • scotch's Avatar
5 years 5 months ago - 5 years 5 months ago
#28609
The pictures of the internal fuel filter is the perfect example of what I was referring to regarding the OEM fuel valve, in an earlier post. I doubt any valve could sustain a positive seal with repeated on/off cycles grinding the internal surfaces with particulate, if allowed to get into the valve.
Last edit: 5 years 5 months ago by scotch.
  • dcarver220b
#28614
Happy to report after the last ~180 mile ride, oil consumption reduced.
Now on to the next issue, Fuel Delivery.
But first, had to service the CBX for tomorrow's ride, after installing an Ivan's ECU reflash into the the 2013 Yamaha FJR 1300.
Like the new bikes, LOVE the old ones...
~d
Moderators: scotch
Time to create page: 0.192 seconds
