Enriching Valve mod
- Bigbadbaz123
- Junior Member
Enriching Valve mod
5 years 4 weeks ago
I've seen it hinted at that this should be removed and a gasket used to seal it. Anyone got the link or complete instructions please. Carbs are coming off to do Scotch's air choke mod, so may as well do this as well.
Thanks!
Thanks!
- rdurost
- Elite Member
Re: Enriching Valve mod
5 years 1 week ago
Looking forward to a response to this--I'd love to hear a definitive answer. In my mind, simpler is always better!
- scotch
5 years 1 week ago
Remove the cover - remove the "guts" - replace the cover with a solid gasket. Done !
Always High - Know Fear !
- z13phil
4 years 9 months ago
Hi Scotch, if these valves go wrong ! what is the symptom ?
- scotch
Nothing can "go wrong".. If you're experiencing back-fire - put the guts back in. Check your mixture, timing and sync. first. Mine have been blocked-off for 2 seasons now and the engine hasn't farted once. And yes.....No Shit: I gained 4-5 MPG. This was one of 4 "tweaks" I did trying to gain mileage. Eventually ended up with a consistent 52MPG @100KPH avg. riding identical runs of 272 Kilometers.
The following user(s) said Thank You: z13phil
- Bigbadbaz123
- Junior Member
Hi Scotch, My 13 has been on hold as life took over, feel guilty not feeding back after all the help you gave me, Hopefully be back on it once winter comes.
Moderators: scotch
Time to create page: 0.165 seconds
