kz1300 banner
Using Pilot adjustment to <slightly> improve carb sync - plug check - sync check
  • dcarver220b
  • dcarver220b's Avatar Topic Author
4 years 1 day ago - 4 years 1 day ago
#30407
2022-06-16 Spark Plug Readings using BP8ES not BP6ES plugs (colder) Plugs came back looking lea nSo installed colder plugs, rode 100+ miles.Here's the results.The numbering is wrong. Really 4, 5, 6. These look much much better than before...
[img
The entire set, electrodes left. 1,2,3,5 look a tad to black.
[img
Electrodes right.
[img
Last edit: 4 years 1 day ago by dcarver220b.
  • dcarver220b
Re: Using Pilot adjustment to <slightly> improve carb sync - plug check - sync check
4 years 1 day ago
#30408
1, 2, 3 inlet ports. Pretty good.
[img
4,5,6 not as good but didn't want to mess with sync... running out of time.
[img
Need to get the spec's from FSM...I discovered one can adjust the pilot jets and slightly change the 'balance'. I tuned by ear and for max vacuum on the stix. These are the results.Video to follow.
[img
Moderators: scotch
Time to create page: 0.169 seconds
