kz1300 banner
Mixture Screws (Again)
  • kwak1261
  • kwak1261's Avatar
Re: Mixture Screws (Again)
12 years 2 months ago
#2631
zed_thirteen wrote: I think the joint between the rear upper air box and the lower air box is very suspect. it's just two pieces joined together with two bolts and no gasket.
I outlined the hole with a light foam draught excluder that would crush down and fill the gap when bolted together. just in case..
Ian
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
  • Toddh
  • Toddh's Avatar
#2633
zed_thirteen wrote: I'm sure your bike wouldn't run at all if you had done this but...
The exploded diagram for the airbox shows the air filter with the opening and foam seal at the top - towards the tool tray.
This is not the correct orientation and the opening must face downwards.
It might run like this - I don't trust all of the seals In the different sections of the air box. I think the joint between the rear upper air box and the lower air box is very suspect. it's just two pieces joined together with two bolts and no gasket.
Hello Zed_13:
Help me understand this one. Open on one side and not the other? My factory air filter is open on both ends, with foam tape on either side.
T.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
  • zed_thirteen
  • zed_thirteen's Avatar
#2634
Sorry, :(
I may have confused people. I have been using a K&N filter which is only open at one end.
I had tried a genuine K paper filter and I thought that was only open at one end too - didn't last long though as a backfire set fire to it while it was in my garage. That was a scary moment.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
  • kza13
  • kza13's Avatar
#2640
There is a gasket, original one had two center bars and a triangular rubber seal on one face, this photo is a replacement one from the german shop, it's missing the two bars that were spaced along the gasket
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
  • zed_thirteen
#2641
That gasket goes between the front upper and lower air box.
I'm talking about rear to lower. The joint just underneath your air filter element - it's just 30 year old warped plastic to 30 year old warped plastic.
Because it is just below the air filter this means that any gaps allow dirty air into the intakes.
1980 CBX1000-A
1990 ZZ-R1100 C1
  • KEL
  • KEL's Avatar
  • Senior Member
  • Senior Member
#2642
Does the Colotrune thing really work as well as you say?
Never seen that before.
Moderators: scotch
Time to create page: 0.177 seconds
