kz1300 banner
Scotch's high MPG tricks
  • dcarver220b
  • dcarver220b's Avatar Topic Author
3 years 2 months ago
#31126
A small correction?    I replaced all the valves.  None burned or damaged in anyway but was the machinists recommendation because he was concerned that reground valves and seats would create a shimming issue.   ie:  Too close to or even tighter then the thinnest available  shim - 2.0mm.
And to reiterate regarding my mileage.  Strict 100KPH limit and multiple identical rides for comparisons..
Stock NGK spark plugs, a GM  6-pack ignition coil and typical silicone jacketed wire wound carbon-core plug leads
  • Modified pilot needles - Polished to a point with a new arbitrary setting of 2 turns.  More sensitive then the stock tip,  the adjustment range for the Color Tune is now approx. +/- 1/4  turn which makes mixture adjustment far more accurate.
  • Enricher mod (Disabled)
  • Precisely sync'd
  • minor adjustment to Ign.-timing.
  • New Brass throughout.  Stock jetting !
Moderators: scotch
Time to create page: 0.150 seconds
