Fuel mileage
- scotch
Fuel mileage
2 years 11 months ago - 2 years 11 months ago
Damned right I framed it !
Conversion; 4.54L per Gal.
.6214K/per mile
The exact same ride at 120-140kph - 44.7 mpg.
Sorry....I don't "do" Liters per 100 kilometers.
The same weekend I did a short ride of 87K on the back-country roads. "Twisting it" like an adolescent boy; I got 27.4 MPG ! The fuel needle dropped faster then the "Titan".
.6214K/per mile
Always High - Know Fear !
Last edit: 2 years 11 months ago by scotch.
- Kawboy
Re: Fuel mileage
I'll assume there was no implosion at the end of the run ( unlike the Titan ) since you lived to tell the tale.
Gotta like those numbers. Pretty sure you own the pole position in the fuel mileage category. Congrats !!
- Ted
Re: Fuel mileage
I had to convert to US to see how that compares. I was able to pull off a 46 miles per US gallon once which is close to yours, but that was with a low speed and sustained tail wind.
1981 KZ1300, '98 Suzuki GSF1200S, Honda CL360, Honda CB350G,'11 Honda CBR250, '75 Honda CL360, '00 Honda XR100R
Speak softly and mount a fast bike.
- BigSix
Re: Fuel mileage
I tried to convert to litres per 100 km. Got 6,11 from Scotch´s data. Guess that is a good value, you probably won´t make it below unless you go slow to save fuel. That is roughly what I use.
regards from metric Europe ...
Holger
Holger
Z1300 A1/ KZT30AG built 1979
frame KZT30A 004285
engine KZT30A 000288
frame KZT30A 004285
- Kawboy
Re: Fuel mileage
Just a little off with the math Holger. He traveled 272.7 Kilometers using 13.285 liters. 272.7 KM= 2.727 100KM
13.285 liters / 2.727 (100 km) = 4.87 L/100 KM
- scotch
Re: Fuel mileage
Ah, the joys of Imperial gallons vs U.S. Gallons vs Liters per 100 kilometers vs miles per gallon !
That's why I stay Ole School with M.P.G. I simply can't grasp kilometers per liter.
Even simpler: When it quits.....you're close to empty......switch to Reserve. When that quits....your walking ! While hiking to the closest gas station you can calculate steps per 100 meters !
Moderators: scotch
