kz1300 banner
new injector
  • hoganter
  • hoganter's Avatar Topic Author
  • Senior Member
  • Senior Member
new injector
2 years 3 weeks ago
#32392
Found an injector from a nissan jecs A46-00 . mine is leaking fuel into the electrical connector.
Any reason why this wont work?
cheersSMP 485cc 46lb Full Length Hose Tail Fuel Injector
  • Kawboy
  • Kawboy's Avatar
Re: new injector
2 years 3 weeks ago
#32393
Fuel injectors are rated for flow at a certain pressure. Just because they have similar body styles doesn't mean they have similar flow ratings. If you're lucky enough to find part numbers on both the Kawasaki injectors and the Nissan injector and can find a crossover reference, you might get lucky, but highly unlikely.
You might get lucky at a fuel injector shop and find a replacement. They can flow test your existing injectors and then find a replacement injector.
  • hoganter
  • Senior Member
  • Senior Member
Re: new injector
2 years 3 weeks ago
#32399
Yes, these are the same body but twice the fuel capacity so may run a bit rich!
fuel capacity is in lbs/hr or cc/min, then there is cc's for the cylinder I think, an ohms reading and recommended feed pressure, aftermarket chinese rubbish and ill informed injector sales people.
good fun
Moderators: scotch
Time to create page: 0.161 seconds
