kz1300 banner
Mixture still too lean
  • scotch
  • scotch's Avatar
Re: Mixture still too lean
1 year 8 months ago - 1 year 8 months ago
#32940
"We often get drivability questions with no history on the bike and then struggle to figure out what your problem is."
This is always an issue when trying to diagnose an issue !
There is another possibility; one which I've seen when rebuilding for others as well as on sets I bought from Ebay.  It would answer the question and solve the problem.  If these spacers are missing you are running the equivalent of having the needle c-clip in the # 2 slot (lean)
https://www.kz1300.com/index.php/attachment/1327
https://www.kz1300.com/index.php/attachment/1328
Always High - Know Fear !
Last edit: 1 year 8 months ago by scotch.
  • Bartus
  • Bartus's Avatar Topic Author
  • New Member
  • New Member
1 year 8 months ago
#32943
This ring is there. All parts inside of carburetor is original.
  • scotch
  • scotch's Avatar
1 year 8 months ago
#32944
"This ring is there. All parts inside of carburetor is original. "
OK .  That eliminates that possibility.  Back to you Kawboy,  while I think of something else !
  • scotch
  • scotch's Avatar
1 year 8 months ago
#32945
My morning caffeine just kicked-in and I had this thought:
Where do you live and what's the altitude there ?
I'd raise the main needles (groove #4), and see if this cures the issue !
  • Kawboy
  • Kawboy's Avatar
1 year 8 months ago
#32946
The stock main jets should be #110 and if yours are #110 then try raising the throttle plunger needles to #4 groove as Scotch has suggested.
The #110 mains and the needles in groove #3 should be good from Sea level up to around 6000 ft above sea level. From 6000 - 8000 above sea level you would go to #105 but you're already running too lean.
  • Bartus
  • New Member
  • New Member
1 year 8 months ago
#32948
Thank you for all ideas. At first i will try to clean holes again. I need to find energy for it....
Moderators: scotch
Time to create page: 0.165 seconds
