kz1300 banner
Mixture still too lean
  • kawaBCN
  • kawaBCN's Avatar
Re: Mixture still too lean
1 year 2 months ago
#33374
Please allow a question from an amateur in reference to the topic discussed: if I ready right you are using NGK spark plugs BP...6.. - is that the correct temperature segment ?
The handbook I have is listing NGK BR8ES. Just wondering ... ?
Holger
Holger, the manual has that wrong. The correct plugs are BPR6ES and you can go to BPR5ES for a hotter plug if needed.  I use the NGK BPR6ES Iridium equivalents and they are fantastic.
What is your place of residence?
What climate do you move through?
Cold, warm, temperate?
I say this because of the temperature rating used in the spark plugs.
RUN LIKE THE WIND¡¡¡
  • zed_thirteen
  • zed_thirteen's Avatar
1 year 2 months ago
#33375
Holger
The UK, so just slightly warmer than yours :-)
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
  • dcarver220b
  • dcarver220b's Avatar
1 year 2 months ago
#33376
I'm running BPR6ES and live in 20F winter weather and 100+F summer weather.
Although, I don't ride the 'water heater' that much in summer. Too hot!
  • BigSix
  • BigSix's Avatar
1 year 2 months ago
#33381
Hi guys,
Did ask the German community: most are using the NGK B... 6 ..
cheers,
Holger
Z1300 A1/ KZT30AG built 1979
frame KZT30A 004285
engine KZT30A 000288
The following user(s) said Thank You: dcarver220b
Moderators: scotch
