kz1300 banner
Fuel solenoid delete?
  • Burto
  • Burto's Avatar Topic Author
  • Junior Member
  • Junior Member
2 months 17 hours ago
#34652
I was wondering if it is ok to remove the fuel solenoid and its associated wiring from my '79 A1 wiring loom as it never came with a solenoid when purchased as a project. It looks like the carbs will function fine on gravity feed from the tank. Also how can I tell what size tank mine is, I believe its 21.3litres.
  • biltonjim
  • biltonjim's Avatar
Re: Fuel solenoid delete?
2 months 30 minutes ago - 2 months 8 minutes ago
#34656
Fuel tank information:
www.kz1300.com/forum/paint-bodywork/2729-gas-tank-size
The USA and Canadian KZ1300 A1 and A2 had the smaller squarish tank.   The A3 and A4 KZ had the more rounded tank.
The USA market KZ1300 B2 Touring had the large tank - the same, I believe, as the European market Z1300 tank.
The European market ( and, I believe Australian) Z1300 and ZG1300 injection  had the large squarish tank throughout the production run.
Last edit: 2 months 8 minutes ago by biltonjim. Reason: Further information.
  • biltonjim
2 months 17 minutes ago
#34657
Regarding the fuel solenoid -  it seems some owners choose to remove it, and replace the tank’s fuel tap with either a manually operated item, or a vacuum type.
www.kz1300.com/forum/carburators-fuel-in...lenoid-problem#31702
Moderators: scotch
Time to create page: 0.166 seconds
