Cracked float bowl tube
- dcarver220b
2 weeks 22 hours ago
This looks like it's been 'sleeved' and the sleeve is cracked too.
Use it or toss it?
If toss, how best to remove the sleeve?
Use it or toss it?
- scotch
Re: Cracked float bowl tube
2 weeks 21 hours ago
Always High - Know Fear !
The following user(s) said Thank You: dcarver220b
- dcarver220b
1 week 6 days ago
Scotch,
Thanks for replying. Appreciated.
Here's more pics..
I measured 4.28 but the crack has expanded the OD - so this may not be sleeved yet?
Pic of a different carb - which makes me think the 'bad' carb does have the restrictor?
Another view of 'bad' carb.. Restrictor installed or no?
Final view of crack.
Here's more pics..
- dcarver220b
1 week 6 days agoPlease Log in or Create an account to join the conversation.
- stocktoy
1 week 6 days ago
could you silver solder it using a small clamp to bring the OD back down close to the OD of the tube while soldering it?
- scotch
1 week 6 days ago - 1 week 5 days ago
"Stick with the Original Plan" and don't over-think the simplest of things ! ! There is a reason: You will NEVER get ANY solder to flow into the crack, regardless of how much Flux or heat is used.
The length of the "tube-sleeve" will depend on the length of the crack......obviously.
Is It Sleeved? If you can see a "crack".......it's NOT sleeved.
Last edit: 1 week 5 days ago by scotch.
Moderators: scotch
Time to create page: 0.449 seconds
