kz1300 banner
2026-06-01 Carb Diaphram Washer Replacement
  • dcarver220b
  • dcarver220b's Avatar Topic Author
3 months 2 weeks ago
#34823
had previously rebuilt this carburetor. But when I installed it on the bike, it was not running good.
The previous owner had installed some kind of a kit where the middle washer.
On top of the diaphragm was replaced with a plastic washer. My guess is they were hoping for faster throttle response.The problem is that the plastic washer overtime had deformed thus presenting a vacuum leak.
So today's job was to find a suitable washer, fabricate it, and install.
I went to the hardware store and sourced several washers of various diameters, thickness, and weight
I decided on this one.
 17 grams.
1.38 mm thick.
The center hole is 1/2 inch, outer diameter is 2 inches.
Now for the fun part of drilling holes. I don't have a drill press so I'll have to do it with a hand drill.
 I used the OEM diaphragm, plunger, sub, clamps, and vice to ensure I drilled in the correct location.
Drilling complete. But I really do need to buy a drill press.
A better picture of the setup.
I had to be very careful to keep the drill square and not hog out the OEM plunger holes.
Here it is installed. I later removed this diaphragm and replaced it with a far superior one from Zed Parts, based in England.
I used a 9/64 inch bit to drill the holes into the washers.
  • dcarver220b
Re: 2026-06-01 Carb Diaphram Washer Replacement
#34835
Any comments, good or bad?
Any suggestions?
I only post what I'm doing as a learning experience.
...and hoping for advice, suggestions.
Don
  • stocktoy
  • stocktoy's Avatar
#34838
Do you have an OEM washer that you can compare the weight of looks like your new one might be a little heavier?
  • dcarver220b
#34844
I do, just have to remember which of the 6 racks has OEM parts in it..
  • scotch
  • scotch's Avatar
#34845
Kawboy, myself and stanG did write-ups about these spacers  Do a Search
Always High - Know Fear !
  • dcarver220b
#34846
2 hours later and still haven't found the posts. I'll keep trying. Lots of other good carb reads tho...
Moderators: scotch
Time to create page: 0.150 seconds
