kz1300 banner
stripped screw
  • Saxgod
  • Saxgod's Avatar Topic Author
  • New Member
  • New Member
stripped screw
12 years 1 month ago - 12 years 1 month ago
#3222
Trying to replace my fuel regulator on the 85 zn1300. The screw on the left side (while on the bike) is stripped. I tried a grabit screw out bit and that had no affect. Any ideas? Thanks.
Last edit: 12 years 1 month ago by Saxgod.
  • RickG
  • RickG's Avatar
Re: stripped screw
#3224
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/kz1300/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: stripped screw
#3225
Hi Saxgod,
I'm assuming that you're referring to one of the 5mm short phillips screws that secure the regulator to the injector rail. I'd grind off the screw head and use a drift to drive out the stripped screw.
You should have no problem tapping the hole for a 6mm screw.
Bill
  • Saxgod
  • New Member
  • New Member
Re: stripped screw
#3227
I was thinking of using my dremel and cutting the head but im worried about sparks being that close to everything lol. but I may have to go that route.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: stripped screw
#3240
I wouldn't worry too much about the sparking issue as long as there isn't an active fuel leak. If the threads on the second screw are good I'd just use a cable wrap through the stripped hole till you take it apart for another reason.
Bill
Moderators: scotch
Time to create page: 0.153 seconds
