Experience with anything but the original air filt
- Raw
- New Member
11 years 8 months ago
I am looking for a stable potential solution to get rid of the large original airfilter.
I know that turbulence becomes a problem with the standard carburettors and funnels, and I also know that I am probably better off with the original air filter in the long run, but is there a good stable solution that some of you have experience with.
I've looked everywhere online for pod filter but can not find any .. :huh:
- strate6
- On An Adventure Before Dementia ! !
Re: Experience with anything but the original air filt
To be honest, there is nothing wrong with the air filter in a stock 1300.
The problem is the air box it lives in. It restricts the flow of air to the filter in a massive way, which is why most 1300's run RICH.
The 3 carbs are all trying to breath thru a tiny funnel behind the side panel.
Its like you having 3 pairs of lungs & trying to breath through a straw whilst running as fast as you can !!!
I have carried out the following mod on many 1300's which makes a big difference but retains the original filter.
1). Remove top part of air box from main lower section under the seat .
2). Cut off funnel / neck so it is flush with the rear of the box itself.
3). On the back flat side of the top air box, drill 9 x 13mm holes in a square formation (3x3).
4). Glue or silicon a piece of mesh INSIDE the top air box to stop insects crawling in or being sucked in.
5). Turn your air mixture screws OUT another 1/4 turn (to make up for extra air intake)
6). Ride your bike.
You should find it pulls better & starts better due to being able to breathe better.
Pete F
UK
6). Ride your bike.
Pete F
UK
The following user(s) said Thank You: Raw
- Raw
- New Member
11 years 7 months ago - 11 years 7 months ago
Thanks for Your tip Pete, that sounds lige a good idea..
I will keep that in mind, and I might end there.., if I can't find a solution on whar I'm looking for..
What I want to do is get rid of the side panels and moving all the electrics up in the back of the old woman.. Like in the style of Caferacers, even though I don't want to make it like a caferacer.. More like a classic racer style, with a thinner fueltank, but with the original seat and rear end.. Might sound crazy to the most of you..
I'm looking for pod filters or another solution that are stable where I can get rid of the big airfilter box..
Last edit: 11 years 7 months ago by Raw.
- Raw
- New Member
11 years 5 months ago
I found What I was looking for..
Here :
www.part-box.com/product_info.php?products_id=37230
You just have to use a stanley knife to make them fit..
[url=
][/url]
Here :
[url=
- aus_z1300
- Elite Member
11 years 5 months agoPlease Log in or Create an account to join the conversation.
- kza13
I bought a spare original airbox, and cut a hole in either side and one in the flat section carby side and put mesh over the holes, so it breathes better, the side covers cover the mesh, and it all fits, make do but it worked
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
Moderators: scotch
Time to create page: 0.162 seconds
