kz1300 banner
High Idle
  • Clark
  • Clark's Avatar Topic Author
  • Junior Member
  • Junior Member
High Idle
11 years 10 months ago - 11 years 10 months ago
#4069
I've been chasing a high idle issue on my B2 and I think I narrowed it down. It looks to be a mechanical issue. The throttle does not completely close (the bracket does not hit the stop per the manual). I can force it closed, but even with the carbs removed it will not close. Is there an adjustment I'm missing? I know the cables aren't top notch, but is there a Band-Aid I can put on this until I get new cables?
Last edit: 11 years 10 months ago by Clark.
  • stocktoy
  • stocktoy's Avatar
Re: High Idle
#4071
Are the carb's all sync'd that might cause the butterfly valves not to close evenly and the idle to hang.
Hope this helps
  • ckiwi
  • ckiwi's Avatar
  • New Member
  • New Member
Re: High Idle
#4080
Question please: How would you buy a carb sync kit for a 6 cyl? I've been searching and can only find 2's and 4's.
many thanks
ckiwi
  • zed_thirteen
  • zed_thirteen's Avatar
Re: High Idle
#4083
I bought a 2 and a 4 and then bolted them to some extruded aluminium angle.
I always hook all 6 up but I reckon you could get away with only connecting 3 gauges as you can't really balance each of the 3 pairs. You can only get the best compromise between the 3 pairs.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
The following user(s) said Thank You: ckiwi
Moderators: scotch
Time to create page: 0.215 seconds
