kz1300 banner
need diaphragm assembly for vacuum center carb
  • patrick1300
  • patrick1300's Avatar Topic Author
  • New Member
  • New Member
11 years 7 months ago
#4378
Working on my 1980 kz 1300 and I've lost the diaphragm assembly for my center carb for the vacuum. And its not made and I can't find one anywhere. Please help. Bike hasn't seen the road since 1990 and that is the only piece to that is keeping it from running. Bike still in poor looking shape but I'm getting it running first then working on making it look good. If any one can help PLEASE!!!!! THANK YIU
  • kza13
  • kza13's Avatar
Re: need diaphragm assembly for vacuum center carb
#4379
www.zed-parts.com/Z1300_parts_shop.html
for the diaphragm, or e-mail them they may have a spare used one, also try www.z1300.de/index.html or e-mail him at mcg@z1300.de , or perhaps someone here might have one if you could let us know where in the world you might be ??
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
  • patrick1300
  • New Member
  • New Member
#4381
I'm in Cumming ga
  • Mikez
  • Mikez's Avatar
  • Elite Member
  • Elite Member
11 years 7 months ago - 11 years 7 months ago
#4401
There should be a set on ebay. Might be pricey for rubber parts but will get you fixed.
If all else fails, I've read before on other forums that nitrile like the kind you find in gloves and gorilla glue can work in a pinch to patch up cracked diaphragms and at least get you on the road.
There's many ways to approach the issue so make sure you've done the research. The information is out there, just gotta know where to look :).
Hope you find what you need!
Last edit: 11 years 7 months ago by Mikez.
  • RickG
  • RickG's Avatar
#4404
I haven't tried this so the usual disclaimer applies but try some Sikaflex, it's a polyurethane glue that is used for glueing panels like on bus bodies, its very flexible, fuel resistant and sticks like shite to a wool blanket. You would need to clean the surface with a cleaning agent like prepsol that is used for cleaning surfaces pre painting with two pack paints. It needs 24 hours to set.
I have heard of it being used but like I said have never tried it.
Use it sparingly as it would tend to stiffen the diaphragm if you put it on thick.
Z1300 A1 x 2
  • Toddh
  • Toddh's Avatar
#4406
No eBay APP ID and/or Cert ID defined in Kunena configurationHere is one low cost option.
Regards.
Todd.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
Moderators: scotch
Time to create page: 0.188 seconds
