IDLE AND FLOODING/CHOKE ISSUE
- SIXPIPES
- Senior Member
Re: IDLE AND FLOODING/CHOKE ISSUE
11 years 5 months ago
Hello Bill,
I can get it to run at 2,500 rpm on the throttle or using the throttle stop screw ( the main one under the carbs) if I use the main throttle stop then it takes an age for the revs to come down should I rev it.
TRIUMPH T120R,BSA A7,BSA A10,BSA SPITFIRE,BSA ROCKET 3 RV,ARIAL SQ 4,S.O.S, RUDGE, BENELLI 750SEI,BENELLI 900SEI, KZ900, SUZUKI GT750, SUZUKI RE5, KAWASAKI H1A, KAWASAKI H2, MOTO GUZZI 850T, NORTON FASTBACK, NORTON INTERSTATE, SUNBEAM S8.
- Toddh
11 years 5 months ago - 11 years 5 months agoSIXPIPES wrote: Hello Bill,
Say Andy:
If it "Takes an Age" for the revs to come down, this suggests a couple of potential problems or both.
1: Its possible you have a vacuum leak, check the intake boots, Air injection system, vacuum nipples on the in take on the head.
2: Your balance adjusters (place where you synchronize the carbs) may be way out of adjustment. Shouldn't be more than 4 turns out, if memory serves me correctly.
3: read the manual on setting the base idle screw. All settings are based on where you have that throttle and fast idle set at.
Let us know.
Todd.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
Last edit: 11 years 5 months ago by Toddh.
- KZQ
- Administrator
- Lifelong Rider Suffering Through MBD
I'm with Todd! Sounds like a vacuum leak.
Bill
Bill
Moderators: scotch
Time to create page: 0.146 seconds
